Zwy
Emperor Of Solar
Use battery powered clocks.I'm guessing it would behave the same regardless what is on L2.
I don't feel like testing again, I'm sick of resetting clocks for the day ?
I have one on my wrist and one for my solar weather station, oh and one on my phone.Use battery powered clocks.![]()
That is true, but your homeowners insurance company may have a say about that, so I think insurability needs to be part of the criteria.Saying something is junk because it is not UL listed is a incorrect view of things. There can be a range of quality in the Tier None products. Victron sells some non UL listed components. It however has a good reputation for reliability and engineering standards.
After the inverter before the 120/240vac loads panel.
Copper or aluminum.
Weight and heat tolerance.
AbsolutelyAnd efficiency (I think) and price.
You kinda lost me, I need to read it about 6 more times. ?In that case, I think wiring a 240/480 primary, 120/240 secondary transformer with 240 || 240 driven by 240V from inverter(s) will draw relatively high no-load current. They are designed cheap, allowed to partially saturate.
The two 240V primary windings in series would make a nice auto-transformer for 120/240V. That will have low idle current, about 1/10th as much (and reduced power handling compared to nameplate.) But using it as isolation transformer, output in series 120/240V windings would only produce 120V.
I would need other windings or a differently wound transformer to get 120/240V split phase out.
Check out my current measurements and waveforms. Secondary 120V driven 120V, primary 240V driven 120V, primary 240V driven 240V.
transformer excitation current - isolation transformer used as auto-transformer
So you think you can backfeed a transformer secondary, either as step-up or as auto-transformer? Turns out these things aren't so ideal and reversible as one might expect. It isn't just the greater inrush (primary is often wound outside secondary to reduce inrush current), but also idle current...diysolarforum.com
Aluminum requires thicker conductors, so current flow is further from core, less coupling. But maybe that's not a bug, it's a feature.
Some of my transformers have multiple windings with about 1/2" gap between layers. Air flow and more leakage inductance. Copper or aluminum would be similar if not packed tightly.
If I'm understanding, you're saying wiring 230 EU inverters to each primary would work nicely for US 120/240 output?
You should purchase one, they might have a slightly used one coming in. https://diysolarforum.com/threads/t...eturning-and-replaced-with-sol-ark-15k.66786/I've been watching. It looks like they may have solved the feeding back to grid issue with a firmware update. We'll see. I'm pretty sure I'm not doing anything until this fall at the earliest, and maybe next spring. If it's the 18kpv I want to see some more track record. If it's something else - well, I haven't found a something else yet that really gets me fired up. Who knows, it may end up being four of the SCCs. I feel fortunate that I'm in a place where my system works well enough that I can wait.
