meetyg
- Jun 4, 2021
- 1,093
I am planning to put an SCC, shunt, battery, fuse box and some other components inside the trunk of my hatchback, as part of my (experiment) solar build.
I was wondering what would be the best "thing" to mount these on/in.
I have seen many just mount the components on a piece of plywood. Seems to be the easiest and cheapest way.
But, I am a bit concerned on using wood, as in case of an electrical short and possibly a fire, that would burn up quickly and take the car with it
On the other hand, wood is non-conductive, so it may be wise to use...
A few more options:
1. A plastic "suitcase" (like the ones some are using for DIY battery builds).
It would make everything tidy, and less prone to harm from things moving around in the trunk. But on the other hand it won't allow airflow (unless I drill some holes...)
2. A small computer case.
This would be pretty nice too, as they usually have air vents (and I could easily add a fan if I thought necessary), and some mounting holes/brackets.
But, these are usually made of aluminum/metal (although painted), and in theory cause a short if a wire got loose somehow.
I don't have to have the case fit the battery, but it would be nice to have it strapped down somehow/to something. I will be using a fairly small 12v 20Ah Lifepo4.
So in short, my main goal is to mount the components other than the battery.
What do you think? Any other (safe) ideas?
Preferably something fire/flame resistant...
Thanks!
A few more options:
Thanks!
