sunshine_eggo
Happy Breffast!
And remember name plate PV watts output is only a tested value that’s hard to achieve for time that’s worth while.
I’d much rather have 1.5 PV name plate going into my SCC knowing that I’d be leaving 10-20% peak output on the table (for an hour or two a day) and capture more power over the course of the entire day.
Yep. While I've seen some nutty performance in special case situations - crazy cold cells, cloud-edging - where output is 20% OVER rated, the vast majority of the time, I'm < 90% rated.
2710/2970 = 91.2% rated.
I'm currently using only half of my existing 250/100 output, but I'll eventually add E/W arrays to ~50% over-panel Watt-wise, but actual simultaneous Isc will still be under 70A.
