In my limited experience, Alodine isn't very durable.Would Alodine work well enough?
I made up welding wire with soldered terminals for a jeep winch, way back when. It worked well enough, but now in retrospect, had those lugs over-heated and the cable let go, it could have been a helluva mess.
I am sitting here wondering why there would be and polychlorinated biphenyls in a LFP battery system because they were banned decades ago....There are lots of high current pcbs with surprisingly small traces, ...
Have you guys looked at the paths and connectors to the components on your bms?
A solid connection is way more important than surface area, and adding ill fitting washers or weird hacks to pad the terminal does more damage than good. Even if you get a good low resistance connection now, it will have a lot more issues down the road.
There are lots of high current pcbs with surprisingly small traces, because the are short and have solid connections to the components.
Ill fitting????? Those washers fit like socks on a rooster!I am sitting here wondering why there would be and polychlorinated biphenyls in a LFP battery system because they were banned decades ago.
D'oh! PCB stands for printed circuit board. Must be a generational thing.
I think you quoted the wrong post. I was making a joke about what a "pcb" is.Ill fitting????? Those washers fit like socks on a rooster!
At least you don't have to deal with these I suppose the advantage is the stud is removable and you have a fairly large threaded area.. what I am planning to do with these is rather similar to what you've done I think I will do one around the bottom and then a large riser to go around it it's certainly not ideal but I think it will increase quite a bit
I did.....the wife was yelling that dinner was ready and I lost all sense of anything going on.....except to get to the table before the kitchen closed!I think you quoted the wrong post. I was making a joke about what a "pcb" is.
Pictures?Without improving the contact area by adding conductive washers around the outside diameter of the Eve 230 AH threaded posts, I have just run a 4-minute test at 150A continuous load into an Inverter. I must note right away that my bus bars are really great, more than 2.5x the cross-section of the pathetic "double thin ones held together with shrink wrap" which I received for free from Docan (shown here.) For each of my 3 bus bars, I stacked the Docan-supplied thin pair above a single better one, built for 270 Ah cells by a different forum member.
Because the "better" ones were drilled with slots at greater distance from each other, I had an opportunity to drill a new hole (in order to fit the Eve 230 cells widths). I made those new holes completely round and only 6mm in size. These better bus bars lie directly on the threaded terminal cylinders, with 100% cylinder coverage surrounding my new hole and about 75% coverage surrounding the other one (at the end of the oppostive pre-drilled slot.). These are all pressed into the "terminal cylinder" by the nut on top of the threaded terminal post. Each threaded post was torqued into the terminal assembly at 50 inch-pounds before adding the bars, washer, and nut. Then I toruqwes the nuts up to 70 inch-pounds, just 12% short of their rated maximum value. (The bottom "better" bars are pressed directly into the terminal "cylinder" posts, with no intervening washer. On each post, a washer is present between the nut and the Docan supplied "thin pair".)
With that thoroughly explained, I also cut off the "B -" terminal lug on my Daly BMS (200A). That terminal lug had a big center hole, it may have been even bigger than 8mm (5/16), and would have done a terrible job of contacting the post (needing washers on both sides). I replaced it with a new lug, hole size 6mm (1/4") to fit directly on the cylinder without any added washer. Although advertised by Daly as "AWG 2" on the insulation, the wire sizes of "B -" and "P -" on my Daly were bigger, very close to AWG-1.
My 12v power lug (for wire size AWG 2/0) has the same hole diameter.
I did not take the time to create a 200A load, but I found NO warming on any of the terminals over a 4-minute period at 150A. Either the "heat" was being pulled into the packs (and I felt no warmth of my steel compression pates either), or the resistive power loss was very small.
Sure. Here's one of my "triple stack" bus bars, and a picture of my Inverter test configuration. I'm replacing the thin and warped compression plates, moving up to 1/4" steel as I used in my previous battery packs.Pictures?
While I don't necessarily disagree that you may be fine without improved contact area, I'm not sure a 4-minute test is long enough to really know if you have some increased resistance that might generate heat. You might want to try it for a bit longer to make sure.4-minute test
How were you checking the temperature of all the terminals?I found NO warming on any of the terminals over a 4-minute period at 150A
Are you saying that your bus bars are made of steel?I'm replacing the thin and warped compression plates, moving up to 1/4" steel as I used in my previous battery packs.
Having misplaced my finicky thermocouple based thermometer, I merely held my finger against a few of the terminals. I agree that to be very "loose" testing, with accuracy roughly 1 degree C. Bus bars are all copper, each built with extremely thin tin electroplate. Direct placement avoided lower conductivity of aluminum washers over the small area of the post cylinder tops, and also avoided "rust" issues with dissimilar metals (the "copper in contact with "aluminum alloy" issue).While I don't necessarily disagree that you may be fine without improved contact area, I'm not sure a 4-minute test is long enough to really know if you have some increased resistance that might generate heat. You might want to try it for a bit longer to make sure.
EDIT: My bad. I guess you are talking about the plates used for compressing the cells? Never mind then.
The heat is generated continuously, but it takes time to warm the terminals and bus bars especially if you are just doing the "finger measurement" of the temperatures. I still think your results may not really be valid at on 4 minutes, but it is up to you.So I'm with you on the accuracy of perceived "terminal temperature" temperature OTOH, I consider a 4-minute test to be totally sufficient, the heat would be generated continuously.
I've bought 1/8" copper bars (5/8" wide for one build, 3/4" wide on three others), and made my own bus bars. For the two batteries that would be in humid conditions on a boat, I nickel plated them. I've got mixed feelings about nickel plating for the batteries to be used here in arid Colorado, as there isn't much electrolyte so the risk of galvanic corrosion is pretty low. Still, it's kinda fun to do the nickel plating so maybe I'll do it.I personally wouldn't stack bus bars that way ..... it adds more resistive contact points .... the same as stacking multiple terminals on one battery post.
What is the amp rating of the thicker bus bar by itself?
Bob, the resistance between the upper "skinny pair" and the lower main bar is governed by a much bigger area of contact surrounding the stud (in comparison to the very small area of the eve post "cylinders"). The bottom "main busbar" handles most of the current, with the small upper pair taking current ONLY when its resistance becomes comparable. And in that case, load on the lower bar is reduced. DC will always follow the path of least resistance, and these bars work together in the same direction of flow.I personally wouldn't stack bus bars that way ..... it adds more resistive contact points .... the same as stacking multiple terminals on one battery post.
