Hi all! Special thanks to
@Kenny_ for starting this log.
I have read all 94 pages today, arrived a lil late to the party but had the same issues you all had and learned a lot.
My set up: SPI-10K-U (same as ASF48100U200-H) paired with 20 Canadian 560W panels and 51.2V 100Ah LifePO4 batt . Happy to say it can generate 11Kw around noon and I have been blessed with 60Kwh days. My setup exports to the grid so it "should" be at max power generation always except for situations I dont understand.
I agree with
@42OhmsPA that you have to read the manual several times to understand the lil nuances eventho it is far from being precise.
What brought me here is something similar to
@CaliSunHarvester experienced. My inverter doesnt want to go back to bypass mode after a power outage, therefore stops exporting excess PW power until I reboot it manually. I'll try setting 03 set to APL and see if that works, I was blaming the battery settings this whole time.
My 2 cents from what I remember reading:
wifi dongle: it doesnt connect to "the server" for whatever reason with some wifi access points but it does with others. In my case, the IPv6 wifi network wont connect, but it does with a basic wifi access point.
Parallel Inverter: I just bought one (SPI-10k-UP) and it is on its way by sea from CN. Same inverter with parallel functionality, let's see how that goes paired with a 30kw battery array also on that ship.
Thanks to you all!
