Yes, that's the one. I have the PowMr version of it. Works flawlessly so far. Just the data coming from it is rubbish. Tells you it has discharged 200Ah from the fully charged battery and then has charged it with 290Ah. It's off by approx. 90Ah within 24 hours. I am in contact with SRNE because of this. Also it cannot calculate the SOC of a battery bank, that has no communication, because there is no parameter to set the size of the battery, so you will need an external shunt, like the victron shunt, if you want to know the SOC of your battery. There are other data flaws as well, but elsewise the machine works well.So this is the same as the SRNE 10K split phase unit everyone has been buying?
Purchased from Sungold?I'm excited that I just ordered Sungold SPH10K48SP for $1569. Hopefully this rig works out well! Pretty excited! Woohoo!
I plan to document my experience with it here! Thanks
Sorry bud was trying to move away from those old threads because one wasn’t mine and I know a lot of guys only look at the “new posts” threads. Just at a real loss here as I can’t believe this isn’t documented somewhere with Sungold as they market it as “batteryless” capable. DIY solar China is the Wild West apparently lolBloody hell how many postings about the same damn problem. Make one thread and stick to it please.
thank you crowz, going to order batts I guess. Not looking forwards to the flashing red lights and beeps, can’t have that. Thanks buddyI ran my tp6048 for a long time with that battery error. With no battery it is going to keep showing the battery error. Once you ever get around to adding a battery it goes away.
Because if you are pulling a full 10kW from the inverter it's going to be pulling around 200A from the batteries. If you keep the load at 5kWh or so a 100Ah battery should be ok.Guys why do you think “Cindy” at Sungold would recommend two of these batts instead of one. I’d like to order one and save up some cash before I do another. Am I ok you think? I won’t have much of a load basically emergency UPS
View attachment 173779View attachment 173780
Because "Cindy" isn't paying for them.Guys why do you think “Cindy” at Sungold would recommend two of these batts instead of one.
what is that transfer switch? Looks like some nice 240v! I am looking for that
It appears that as long as Utilities priority is set to default in settings the machine will feed the demand load with PV input from panels and any shortage of watts will come from the utilities. What I do find annoying in the programming is you cant set a parameter which would null all additional battery parameters so that the machine would 'understand' their is no battery attached. The machine sounds an alarm the battery is missing and it also still tries to pump amps into the batt because the voltage threshold of 0 is lower than the battery charged threshold. Their is no battery load tho...so it's not costing a tremendous amount of performance, but it is loading components that it wouldnt otherwise load had the machine understood to run batteryless. You can just tell the programming is not thought all the way through.... guess i can't complain though.. i don't possess the knowledge to fix the software either..Without a battery, it just runs in bypass mode, meaning it doesn't use any solar power, or am I missing something?
do be cautious on which model you get, regardless of who’s name is on it.I'm looking seriously at possibly going the Sungold or Sol-Ark direction...
