jester74
- Jun 13, 2022
- 6
I’ve got a 10kw Sungold on the way. Do you know if I can use it in UPS mode while it’s plugged in to grid via main panel and using a non-neutral-switching MTS where circuits get their neutral from same main panel?Temporary install of SPH10K48SP for testing. We have a Growatt 12kw system, but it faces issues with down time and not enough volts to use solar array properly. The best thing about the 10kw Sungold is that it amplifies the PV volts to 500V input. This has been great and was able to quickly restring our 24 panels to raise the volts. However there are some draw backs and waiting for Sungold. First the SmartEss app is not ready for prime time. The app WILL ONLY chart PV 1 input and not PV 2 input. Second it will also only chart HOT 1 or L1 and NOT HOT 2 or L2. The WiFi dongle was terrible at set up. I’m waiting for Sungold to respond if there are other options or changes that can be made so the app produces the correct data for PV KW and for Load KW.
