Thank you for this Very informativeLooks awfully familiar...
4 MWh SRNE ASF48100U200-H 10kw.
Edit 4-12-24 4,000 kWh Edit 3-23 Current Settings. Edit 3-4-24 3MWh https://diysolarforum.com/threads/2-mwh-srne-asf48100u200-h-10kw.67809/post-1027777 Edit 1-2-24 2MWh AC output, close to 2MWh solar. https://diysolarforum.com/threads/1mwh-srne-asf48100u200-h-10kw.67809/post-966398 Edit...diysolarforum.com
See the SRNE link I posted above...Talked to SunGold today about my requirements and they recommended this unit. I was originally interested in BluePower IP6048, especially for the IP65 rating, but I am seeing some weird reviews/experiences about that unit so I am hesitant. Not a whole lot of info out there on SunGold SPH10K48SP it seems.
Gotcha, yeah guess the PowMr you see on Amazon are also this unit. I may lean away from this unit and investigate doing (2) 6.5KW BluePower SP6548SOLAR INVERTER / CHARGER which I believe are clones of the MPP Solar LV 6548 which have been better received by the community I thinkSee the SRNE link I posted above...
Be cautious with the 6548s...it's my understanding the pre 'covid' units are quite reliable, the post with the higher max voc are a tossup.Gotcha, yeah guess the PowMr you see on Amazon are also this unit. I may lean away from this unit and investigate doing (2) 6.5KW BluePower SP6548SOLAR INVERTER / CHARGER which I believe are clones of the MPP Solar LV 6548 which have been better received by the community I think
There’s a reason some of us are trying this 10k instead of the mppsGotcha, yeah guess the PowMr you see on Amazon are also this unit. I may lean away from this unit and investigate doing (2) 6.5KW BluePower SP6548SOLAR INVERTER / CHARGER which I believe are clones of the MPP Solar LV 6548 which have been better received by the community I think
Thanks for your reply! Well stink.. after hearing that I don't know what to do.. What should I do? Here is my panel setupBe cautious with the 6548s...it's my understanding the pre 'covid' units are quite reliable, the post with the higher max voc are a tossup.
Your link is broken.Thanks for your reply! Well stink.. after hearing that I don't know what to do.. What should I do? Here is my panel setup
https://diysolarforum.com/threads/string-configuration-question-%F0%9F%98%87%E2%98%80%EF%B8%8F.70569/#post-893090
Maybe I should stick with original plan and commit to SPH10K48SP
My buddy scared me away from it because I can't parallel. I guess that's what got me interested in 6548 so I could add on as my budget allowed..
Man I just don't know what to do.....
42OhmsPA how is SRNE holding up now? Still good?
That’s a great, I like the idea of redundancy. InterestingYour link is broken.
It's holding up excellent, still have 0 regrets.
Think about this you could buy 2 of the SRNEs for around the same price as the Voltronic 6548s... Split your loads panels and put an SRNE on each panel... No parallel needed.
Temporary install of SPH10K48SP for testing. We have a Growatt 12kw system, but it faces issues with down time and not enough volts to use solar array properly. The best thing about the 10kw Sungold is that it amplifies the PV volts to 500V input. This has been great and was able to quickly restring our 24 panels to raise the volts. However there are some draw backs and waiting for Sungold. First the SmartEss app is not ready for prime time. The app WILL ONLY chart PV 1 input and not PV 2 input. Second it will also only chart HOT 1 or L1 and NOT HOT 2 or L2. The WiFi dongle was terrible at set up. I’m waiting for Sungold to respond if there are other options or changes that can be made so the app produces the correct data for PV KW and for Load KW.I'm looking for a review on this AIO inverter (SunGold SPH10K48SP). If there is a review, I am appreciative for a link.
