Dinobot248
@Adam De Lay
I wanted to say thanks for posting your "Different Ways to Ignore AC Input on a Victron MultiPlus 2 Inverter" video. Link is below.
I recently invested in the Victron ecosystem (MP II 48/5000, Lynx Distribution kit, Cerbo GX, SCC, etc). With one Multiplus running single phase 120v, I am now able to run my whole house while using the grid as an automated backup for loads over 4500w.
The new system has been running for about 3 days and the new assistants have been running for about 15 minutes. AC input correctly shut off when SOC reached 80%.
So far, what I really like about my new system ...
1. The AC input integrates very well. When I set it up 30A AC input max, it first covers the house loads then charges the battery with the remaining. The EG4 6500EX took a different approach and would apply the full 30A AC input to the battery and draw additional AC power to cover the house load. This meant that I could blow fuses since I did not know what the actual draw from the AC input would be.
So far, what I don't like or don't understand ...
1. Computing or verifying efficiency of the inverter is difficult when Victron appears to list VA (volt amps) as watts and there is no power factor listing. If looking at the Remote Console, I think the AC Loads (green box) is showing VA (volt amps) as watts.
Thanks again !!
My Solar Todo and Wish List
1. Tweak the grid start and stop thresholds to better fit my situation. Currently set at 4500w to enable grid and 2000w to disable grid.
2. Install 6awg THHN wire for AC input. Currently jerry rigged two 12awg extension cords and running max AC input at 30A.
3. Clean up and align the wiring for my load center. It works but wires are like sphaghetti.
4. Post an unboxing of the Oasesenergy 12v 100ah lifepo4 battery. I bought it since you can open the battery and cells are supposedly mounted in an internal metal rack and not glued. Battery should arrive second week of the new year.
5. Build my first DIY battery with grade B 305ah cells from 18650 battery store. Chose the the Over Kill BMS. Its more expensive but warranty is idiot proof e.g. free replacement if I break the BMS. Cells should arrive first week of the new year.
6. Cut some trees to open up the canopy and collect more solar
Thanks again !!
