mikeking
- Jan 5, 2021
- 2
Hi All,
I have a Dragonfly Trimaran (28 Sport) that I've had for a few years now. I've changed a few things over the years as needed, but am looking to do a bit of a project on her to a) clean up some of the things I've probably done wrong, b) give myself a bit more capacity to play with and c) because I'm interested in this stuff. Alongside this I'm also building a compute system using OpenPlotter (Raspberry Pi, Node Red, MQTT, Grafana etc.) that is hooking into the NMEA200 data.
The boat has a lot of electronics on it (Raymarine catalogue got dropped all over it by a previous owner) and while I have a 100Ah Rolls AGM battery, no expensive things like fridges and LEDs only, I still get concerned if I have to depend on the Autopilot for overnight stretches and have issues like radios reporting low voltage, chartplotters restarting due to voltage drop when starting the outboard etc. I'm going to do some checking on consumption, but I think I'm around 6A (72W) usage on autopilot. I would like to add a fridge, and to be able to run the heating fan when it gets icy, and in the UK at the moment, it's a tad cold.
The solar was updated by me recently (Sunbeam Tough 78W and Victron 75/15), replacing the old, and failing, Sunware 64W and Fox PWM controller. I'm limited on the amount of solar I can fit on board (she's a bit of a slim thing) although I could possibly get some slim panels on the amas, but don't like the thought of routing those cables through folding mechanisms. I also have a Honda 10hp outboard that has an alternator (I think 6A). Everything runs off the one battery as weight matters on these boats.
I'm thinking of building a DIY LiFePo4 battery, something like 200Ah @12v and doing a refit of the electrics. I'm concerned that I can't get enough solar to charge that size, and from what I read the alternator on the outboard is more likely to combust than charge when low.
Alongside that, ideas on BMS systems that could be integrated into a Rasperry Pi/NodeRed system (I'm liking open source like ElectroDacus over throwing money at brands) would be welcome.
Comments, pitfalls, abuse etc. all welcome.
and thanks @Will Prowse. Your videos have been most informative.
Thanks
Mike
Thanks
Mike
