They must do electric different in Iowa.
The compressor motor will use the same Watts while running. If the temperature of the unit shuts down the motor, It uses no watts. But when it is running it uses the same watts.
The overall use of power is Watt Hours. That is a measurement of Watts that are used over a measured time. The motor still needs the same Watts while it is running.
That quoted post was made because this whole thread went well off track. A real train wreck. I'm sorry we can be so nuts.
Just for information; The manual for my Samlex inverter would size the inverter for that fridge at 173 times three for a 520 watt inverter. Sized up to what is available. I guess 1000W maybe.
I am glad you solved the problem. That problem was voltage drop. Bad connection caused voltage drop. See post number 5 above.Start Up Amps/Watts = 6.3 / 724.5. Running Amps/Watts = 1.5 / 172.5 is the rated.
So you're saying it needs three times the start up?
If that was the case it seems like the inverter would have trouble on start up, not after a few hours of running when its already done the major cooling work
