Sipma02
- May 27, 2020
- 141
Hello all,
I'd like to tap into everyone's experience here to see if there is any general knowledge of an inverter with a strong surge capability. I'm hoping to run a fridge which, upon startup, draws about 1000-1100 watts (as measured by my Kill-a-watt meter). When running, it's rarely above 80-100 watts! My thought is to buy an inverter with around 500 watts of nominal power output, with a surge of 1000. Otherwise, is there a way to modify an inverter for higher surge capacity or bypass the high draw shutdown? I'm fairly handy with a soldering iron and could potentially replace a component or two.
Any other ideas to use a more efficient (smaller and cheaper) inverter? Maybe some way to use one inverter to "start" the fridge, and one to keep it running?
The inverter will be dedicated to the fridge, no other loads.
