I bought two of the MPP LV6548's from Ian at Watts247 also. Great service and fast. Ian is also very helpful when you have questions.I run the MPP 3kW 48v, and it's worked flawlessly so far.
I didn't buy it from a Chinese vendor, with the possibility of a knock off copy, no support and problems with warranty claims, but from Ian in Utah.
Yes a few bucks more expensive but well worth it for peace of mind and knowing you are getting the genuine article with a warranty. Plus you will get it within a few days from ordering, rather than within a few decades if you order from China.MPP Solar – Watts247 Wholesale
watts247.com
What european supplier and distributor did you buy from? ?about all of the above are rebranded voltronics.
powland is a cheap clone...
i'm using the voltronic axpert 8000 max now, before i owned 2* mpp solar mpi 10k's.
the main difference between mpp and the others you mentioned is support, or rather lack there of.
the reason i choose the axpert this time is also simple : support and warranty.
i bought them from an european supplier and distributor, he has to abide eu regulation, therefor adding 2 years of extra support and a "local" point of contact in my timezone
Solarpower24.it ( eu warrantee , support, and good bunch of guys doing good by their customers) I used as for the last inverters I bought, before that I bought directly from mpp solar ( before I found out solarpower24 sold voltronics in eu)What european supplier and distributor did you buy from? ?
Nice. ? What Voltronic Axpert do you have?Solarpower24.it ( eu warrantee , support, and good bunch of guys doing good by their customers) I used as for the last inverters I bought, before that I bought directly from mpp solar ( before I found out solarpower24 sold voltronics in eu)
Voltacon ( uk, es) sells voltronics too, but no experience with them
Great post. Very valid and something many DIY folks don't take into account.I feel I need to speak up about something left unmentioned that is pretty important to most people and it applies globally. Home Insurance is a PITA and they take every step to avoid payouts which makes them a Pain but for good reason too... too many fools result in tight requirements.
Things to consider:
- What does YOUR Insurance company "require" to cover your solar system and any structures using it ?
- Does the equipment have to meet National/Regional Certifications such as UL, ETL, CSA etc... probably others too depending where you are.
- Does it have to be Professionally Installed or can you DIY ? (Assume a Pro install includes inspections & sign off)
- IF DIY is acceptable, will it also require an Electrical Inspection & sign off ?
FYI, Most companies DO REQUIRE certified Commercial equipment & Electrical Inspection & Sign Off BEFORE being Covered. Some companies will NOT deal with Solar at all.
DO YOU KNOW What is required by your insurance co ?
99% of mortgages require insurance and without it, your mortgage could be in danger or may not be renewed by the lenders.
A TWIST !!!
In some jurisdictions, you can GET AROUND certain issues by having a separate "Power House" which contains all the solar gear (Inverters/Batteries etc). They can either wave coverage on that structure or provide a separate rider to cover it independently. Again there is always the question of certifications & inspections and every company is different so...
There are many horror stories with regards to solar & insurance and the stupid games Insurance can play on people... Don't become one of those stories.
Especially worsened by companies pulling out of various regions and areas while hardening up their requirements at the same time. Lot of folks are learning hard lessons right now and while it is making news it is being kept low key for now. Albeit folks in California, FLA and such are facing the issues hard now.Great post. Very valid and something many DIY folks don't take into account.
I have heard stories where an insurance company would not cover a lightning induced fire because the owner did not have his 10 gauge wires from his panels inside conduit. They will use any excuse not to pay.
8000 max, but replaced them a few months ago by sunsynk's..Nice. ? What Voltronic Axpert do you have?
Ok ? Why did you replace them?8000 max, but replaced them a few months ago by sunsynk's..
Of 3 still have one looking for a new home, others are in use at friend, and runs his home at full satisfaction
Because I wanted to netmeter, 3 phase in one inverter and all the extra bells and whistles sunsynk ( deye/sol-ark) had to offerOk ? Why did you replace them?
Send you a PM, I would take your phone number off the public part of the forumHi mate, I was wondering if you still have the chinese inverter/charger hybrid for sale? I was doing a bit of research into a cheaper system as my Victron Lifepo4 homemade off grid setup just burned to the ground in a wildfire here in Portugal. I am trying to get me and my business back on my feet asap and funds are tight. I saw you are trying to sell the last one of four units? I would be very interested! You can also call me on [redacted] Many thanks, Rick
Wow, that sucks. My son just returned from Portugal yesterday. He loved it there. Where was the fire? A friend of mine recently had a similar issue with an Antifa guy setting his yard on fire ( he is adjacent to a forest). He actually chased him off the property, and thankfully was able to put it out before it spread.Hi mate, I was wondering if you still have the chinese inverter/charger hybrid for sale? I was doing a bit of research into a cheaper system as my Victron Lifepo4 homemade off grid setup just burned to the ground in a wildfire here in Portugal. I am trying to get me and my business back on my feet asap and funds are tight. I saw you are trying to sell the last one of four units? I would be very interested! You can also call me on 00351 960153102 Many thanks, Rick
