Check out the thead under DIY Powerwalls about the custom case for 280Ah batteries. They are stackable, you could fit them in a rack if the rack was equipped with suitable shelves for them, but otherwise they are just designed to stack on top of each other and latch together.Is anyone making server rack enclosures for the 280Ah cells?
Thanks guys.
16 x 5.2kg cell16 cell 48V enclosure would be a beast...probably 350 lbs
This is how I did mine, not server rack but had custom metal rack made for a cabinet from Lowe’s. Then used 5/16” aluminum plates for lite compression.Is anyone making server rack enclosures for the 280Ah cells?
Thanks guys.
Probably have another 25 KG in wiring, buss bars, support material and BMS so 135-140KG = 308 Lbs16 x 5.2kg cell
1 x 28kg case
111kg or around 250lbs
The case weight includes all that stuffs. And it's not (close to 40kg) because I just bought four of them, it weighs 28kg all in.Probably have another 25 KG in wiring, buss bars, support material and BMS so 135-140KG = 308 Lbs
Actually I think the case will probably be closer to 40KG by itself.
Thanks. In the final stages of completing our house. About 2-months out ATM....@Shawn Hayes setup looks great. How is the system running with a battery bank that size?Also where did you get your cabinet/shelf?Thanks
edit - just reread that you mentioned lowes.
So here are my photos of the system completed but idle. Added the breakers but system as I mentioned earlier not hooked up to Sol-Ark yet.@Shawn Hayes setup looks great. How is the system running with a battery bank that size?Also where did you get your cabinet/shelf?Thanks
Are the cells working ok mounted in that position? I was under the impression flat mounting them was not ok.So here are my photos of the system completed but idle. Added the breakers but system as I mentioned earlier not hooked up to Sol-Ark yet.
When I actually get this up and running I need to revisit your disconnect strategy and localized monitoring setup.
I do not know. I have all mine mounted terminals in the upright position. Just noticed your position and wanted to check.I thought flat mounting on side (even electrolyte coverage) was fine, flat mounting in edge is what you want to avoid.
Based on research I have seen, laying them horizontally is OK. I have seen it both ways however. So far my batteries are OK. However, keep in mind that my system is running off my large DIY LiFePo4 packs are NOT connected to my Sol-Arks yet.Are the cells working ok mounted in that position? I was under the impression flat mounting them was not ok.
At the time when I built the rack and mounted those batteries in the horizontal position, I did not have enough room to mount them in the upright position laid out on the floor. However since my initial build I have been able to free up some room and if need to be, in the future, if the packs laying on their side horizontally does not work, I can then re-orient them in a different manner with the terminals facing upright.I do not know. I have all mine mounted terminals in the upright position. Just noticed your position and wanted to check.
I would NOT wait until there are problems with the position, I would research and get confirmation in writing BEFORE I set them in use because you have a LOT of cells there. If long horizontal is not allowed, they will all bloat, and or fail dramatically...At the time when I built the rack and mounted those batteries in the horizontal position, I did not have enough room to mount them in the upright position laid out on the floor. However since my initial build I have been able to free up some room and if need to be, in the future, if the packs laying on their side horizontally does not work, I can then re-orient them in a different manner with the terminals facing upright.
Get confirmation first.
Thanks for the info. I’ll have to go back and look at the research I did when I was building this battery back. I think other people were orienting batteries in this manning, but if they have had issues with it I guess I am not aware of that?
How do you deal with something like pre-charge resistors with this setup?So here are my photos of the system completed but idle. Added the breakers but system as I mentioned earlier not hooked up to Sol-Ark yet.
