Is there a charger that will do everything?
Jmhai3
United States
I have been looking for this but can’t find an exact answer.
Is there a charger that will charge all batteries? 12, 24, 36, and 48volt.
I see there is the desktop power tester that are infinitely adjustable but are they safe for all types? Lead acid, lipo, AGM, and etc.
I have miscellaneous tool batteries, 12, and 48 volt and would like to limit the stuff I have to maintain them when not in a system or setup.
The only difference between a power supply and a charger is that charger will have a charging profile or profiles that are suitable for various chemistries.
If you can adjust the voltage and current on a power supply it should be fine for any chemistry though it may require active monitoring on your part.
If the tool manufacturer has such a thing that would be it.
Otherwise for different brands and voltages I recommend sticking with the OEM equipment.
Next tool purchase limit yourself to existing infrastructure.
I guess most people will have multiple charges for different voltage?
Depending on how things workout with the EG4 3k that is down waiting on SS support will need a way to charge the 48v lifepower battery if I go with just a inverter
I would not try it. I yesterday found one which I won’t link, but saw on Amazon or eBay when searching door 48 VDC chargers. Didn’t explain the voltages or different stages, but had a switch for all four voltages.
Without knowing the charge voltage, you’re taking a risk of it being for lead acid and bein too much for lithium.
I am finding out the same info. Will see what ends up happening with the AIO unit and see if replaced.
The suggestion of an MPPT could work. THe flexmax was mentioned, but there are many MPPTs that have 12, 24, 36, or 48 VDC options. Prior to my top balance, I charged my Lithium cells in an 8S battery pack with a VIctron MPPT.
I had wanted to do a battery charger, but it did not show in time to build the battery.
I also have three times recently having to wake up a BMS with a trickle charge current from a power supply. One time was for a 24 VDC I over discharged, one was to bring a Ryobi Battery back to life, and the last was for a a 48 VDC battery pack. I have a 30 VDC adjustable power supply, but someone else woke up the 48 Volt battery for me.
It would be great if there was a charger of this type and the current could be replaced correctly.
I am not sure this charger would be good to charge a battery. Without giving the actual charging voltages for each setting, I would avoid these multi-voltage chargers. If you could set them voltages like for an MPPT, that would be fine.
This Beelab is the one I did not want to link earlier. Not sure of the voltage it charges at, which I think could be too close to the max charging rate, especially if cells are unbalanced.
The two settings for each voltage are 12/24/36/48 for each voltage plus a high setting. The high setting seems like it equalizes, and the regular setting, not sure what the chargign voltage for each of those are. I would not want to charge above 14 volts per 12 volts for a lithium and preferably 13.6 volts so to avoid pushing too much voltage into an unbalanced high cell.
I had some of the same thoughts you do about a charger like this, if you read in the description and look at the zoomed pictures, the voltages (bank) are adjustable, and have a low, med, and high amps for all of those (but of course not able to fine tune absorption or float voltages). Not saying that would make it a 'good' charger, but perhaps someone would want to test one.
I come from the 80's when brands were a thing (a way to get an idea about quality to some extent), and when you saw brand names you never heard of before, it would kind of made me wonder about how good they were, where these days, most everything is made in a certain large country (with all brands you never heard of before), where quality can be hit or miss either way, where one almost has to try the thing out to know if it is a silver bullet or a throwaway item.
It might be the kind of charger where you don't just want to set on charge and walk away too long, rather to keep an eye on it, see how it's doing. I'm not really into this kind of charger, since they're trying to be a one-size-fits-all thing (where they often times suffer at doing any one thing optimally). I would definitely prefer to use a Victron MPPT over something like this, where I can set a battery bank voltage and custom chemistry charge profiles, all from bluetooth.
I rather just have different chargers to do specific things (for bench / shop use), like my 12v or 12v/24v chargers for shop / automotive, and the 48v charger with LFP / AGM / GEL / SLA profiles for bench charging in that range, and a digital power supply (like RD6018 or something) for doing anything in between that I don't commonly charge, or like for top balancing the 3.4v LFP cells or something. I have an RD6012 now, which was the max amps model they sold at the time, and I like it a lot for doing manual power supply stuff and custom charging (where I will babysit it, change it from absorption to float voltage or stop charging on it as needed manually)...
A handy option is a boost controller like the MPT-7210. This is all programmable and can do 72V @ 10A plus they are cheap.
This may be digressing away from the OPs original question, but I am looking at something like this 0 to 60 VDC, 0 to 5 amp power supply to wake up BMSs or to trickle charge a battery until it has enough charge to put on a charger.
Although it could charge any battery, at only 5 amps could take forever and it would not auto kick into the next stage.
Just a quick Google brought up some examples of chargers that can supposedly do all the voltages...
Example:
Or could just use a Victron MPPT charger like the 250|100 I have...
That does look like what I’m looking for. Will do more research into it.
Thanks.
I see some mention of mppt but looking for AC to DC for now.
I’m going to start another thread for the EG4-3K AIO unit issue, which looks like will need to go back to SS to repair.
Easy. I connect a laptop power supply to mine for charging. 19V in and whatever voltage greater then that out.
Can you explain more? It will adjust to the needed input for whatever battery it is connected too?
For everyone reading this post.
I did start a new thread for the AIO unit in the Solar equipment reviews and tech support forum section (all-in-One Systems). Please take a look if you are interested that issue
Just Google or search the forum. They are a simple charge controller that only works as a boost converter. Output voltage is always higher than input. I was using it with 18V panels on a 24V battery.
You can set the output voltage and current up to 72V @ 10A respectively. You don't have to use solar panels on the input. Any DC voltage source will do. I connect a Dell laptop brick to it to top off a small 24V battery I have.
Don't know the minimum input voltage but it would certainly let you charge 24 36 & 48V batteries from a common supply.
I wonder if one could just build a simple full wave DC rectifier circuit (4 diodes) to make a DC out of a 120v AC power source, and feed that into the PV input of your favorite MPPT charger (which has multiple battery bank voltage options), if the ripple wouldn't screw with it too much.
Example:
