is this cheap bms can do the work
gamer
in my country i have only this bms is it good or i need to look for samthing alse
i want to build 2X100 ah 4S 16.8V lithium battery
Is there a reason you are using 18650 cells to make 2 big batteries?
Why 16.8V? Is there a particular use for that voltage?
Sorry, i do not know about that BMS as there does not appear to be a brand or model or maker listed.
no no reason i was told its better 3S for 18650 cells. can you give me cheap bms because the daly ones are expensive for me right now
Ok, 3.6V nominal.
What voltage battery are you trying to make?
3S = 10.8V
4S = 14.4V
So you would need a 3S or 4S BMS.
What are looking to power with your battery?
i have victron inverter 12V 2000watt 9v to 17v I WANT TO MAKE 2x150ah i dont know if i should make 4S or 3S i. use max 240 WATT PER HOUR IN THE NIGHT ALSO I DONT KNOW THE TICKNESS OF THE NICKEL I CHOULD USE ALL MY CELLS ARE 2a
I would do 4S (14.4V nominal, 16.8V max) since that falls nicely in your inverter range.
To make 150Ah from 2Ah cells
150/4 = 37.x cells in parallel. You are more ambitious than me!
150Ah x 14.4V = 2160Wh
2160Wh / 240W = 9h runtime
Does the 240 W include the inverter loss (~15%)?
i didnt understand the last part i have another hybrid inverter working right now but its 48V it shows me the consumption thats where i get the 240 WATT
Is that showing battery consumption or appliance consumption?
If appliance consumes at 240W rate, battery is likely being drained at (240W / .85) = 282W
2160Wh battery / 282W = 7.6h runtime
i will build just one right now this bms are expensive but it hase balancer in it i also have to ship them from aliexpress
i think 3S is better for me so the inverter can cut off at 3v per cell
i looked on amazon and AliExpress for 18650 4S BMSs and do not recognize any so cannot really recommend one.
What you will need is one that handles your max battery amp draw. The 2000W inverter could draw quite a bit (2000W / .85 / 14.4v = 163A).
But if you only need to handle ~300W
300W / 14.4V = about 20A BMS (minimum)
The BMS in your first post looks sufficient for 4S up to 100A
what wait is it if you have 150AH battery you need 150ah bms? im confused
sorry if this is annoying. battery energy capacity usually Ah (amps x hours) and bms current capacity usually measured in A (amps)
150Ah battery not necessarily need 150A BMS. why? some battery can't do same number of amps as their amp hour number rating (2Ah cell compared to 2 Amps). some 2Ah cells can only do 1Amp if that makes sense.
"low power cell" like 2Ah can only do maybe 1Amp continuously until empty
"high power cell" like 2Ah can do maybe 4Amp continuously until empty
hope this helps, sorry if annoying to focus on that.
