My plan when there is excess Pv production to dump it into heating,cooling, and charging my car batteries. I'll have to check out victron as they seem to have that capability as well.
Is that a specific feature of certain systems or is that how solar systems work in general... Pv to load to batteries.... Or is it usually pv to batteries to load?
Your "Dump Load" to soak up excess only works if it can always take the power. If dumped to a water heater, what happens when that reaches high temperature cutout? If dumping to any AC load, what happens if inverter can't continue to deliver, either because it derates on a hot day or is otherwise shut off?
If your dump load can't take the power, it flows to battery. BMS then has to disconnect.
Traditional off-grid systems were PV --> SCC --> Battery --> Inverter --> AC loads
Battery had to accept peak current coming from solar power. Holding optimum charge current for FLA wouldn't happen (except if excess PV, and SCC clipped at spec'd current)
Victron's ecosystem supports the above configuration while regulating charge current, by measuring battery current with a shunt and communicating.
SMA's AC coupling and some others are PV --> GT Inverter --> AC --> Inverter/Charger --> Battery
The inverter/charger is programmed for a maximum battery charge current. PV could be sized several times that, and only target battery current is delivered. GT inverter is commanded to adjust its output to match AC loads + charging.
That's what I have.
During AC load-dump (A/C or well pump turns off), it can take some seconds for Sunny Island to raise frequency requesting reduced power. I think SI momentarily sucks down excess power and shoves it into battery. If so, that could be a problem for BMS which has a strict current limit. Lead-Acid can take a momentary surge. SMA recommends 100 Ah @ 48V per kW of AC coupled PV inverter. I have several times that much PV (undersized battery). What I don't have is AC loads approaching inverter capacity, so haven't done such large load-dump.
