Samsonite801
Solar Wizard
- Oct 15, 2020
- 2,994
I can double the number in my head is close enough for me. Yes they don't discharge perfectly equal either but still close enough. Worst case l have to look at both. Mostly just a curiosity anyway as I have way more power now with no more worries. Never had a shunt before and they seem to have their own periodic issues too.
So I have the 6 Overkill BMSs now in parallel, I can log into any one of them and get an idea of SoC, since they are all usually within a percent of each other. However, one reason I did purchase a Victron BMV-712 shunt was because it has a POE data cable / remote display which I can mount in the living area (in the kitchen), and it has the actual bluetooth radio on that remote display unit, so it gets a nice strong signal from anywhere in the motorhome front to back.
The Overkill BMSs, and their bluetooth radios of course, are in the basement of the coach, and so to even be able to get a good enough signal to connect to them, I pretty much have to go stand (or sometimes even kneel down) right over the floor above them in order to connect.
I do like to log into each one of them periodically to make sure none of them have tripped or anything. I did have one trip before when one cell was out of balance.
But for normal daily use, I'd just like to see the one SoC indication and it's also nice to have the voltage, battery bar, and SoC percentage indicator, battery temperature, etc, on a physical display in the kitchen too (so it doesn't require opening a software app to see it)...
