JK BMS GPS Connector
Bundyblu
Hi
Can anyone inentify what type of connector the GPS Port uses on a JK BMS Type JK BD6A20S10PC
The JK BMS is the new black model.
Would you know what type of connectors the Can (3 Pin) and the LCD (6 Pin) connectors. Thanks
Edit - probably bad info below but I'll leave it for anyone with a JBD.
They look like the same size as JBDs, you'll need to measure and make sure.
I used these, they shipped quick; make sure you select the version you need.
$0.60 | HY2.0 Connector with 20cm 26AWG Cable Wire Butt Connection 2 3 4 5 6 7 8 Pin 2.0mm Pitch Male Female Plug Socket
Hello Bundyblu,
I'm starting a new project to extend to JK-BMS a 6 months logger I made for DALY BMS .
I already found all the protocol info I need to communicate with JK , the only doubt I still have is coming from the DS : http://www.jk-bms.com/en/Upload/2023-12-05/1746328565.pdf
I will use UART connector to be compatible with my current HW.
UART connector is "P5" on JK meant for GPS. Is a 4 pin JST 1.25 ( or it should be )
Pin P5.1 is stated to be VGPS ( ... close to B+ ) .
QUESTION: Have you tested this Pin during your development ? is really B+ ( on 16S it should be around 50V that makes no sense for me )
Thanks for replying.
P.S. asking because I don't have a JK-BMS - I will work blindly this time .... simply trying to add the JK protocol .
For your ( and my fun ) this is a Zoom IN of a 24h log from my logger :) notes - yellow boxes and red arrow are added later
Hello Bundyblu,
I think I found the answer by myself ... :) YES VGPS is B+ , I won't use it . Activity to make my dongle compatible with JK already at a very good point . Stay tuned !
