brainwashed
I have the B1A20S15P hooked up to a bank of 16 LPF cells, has been running great for months now. It suddenly shut down and won't turn on. I can briefly force it on using the LCD button but it then shuts off after one second. The bank voltage is 56.8, temperature sensors are not tripped, there was no overcurrent or anything else. Since I monitor the entire status in Home Assistant, checking out the graphs nothing jumps out. The phone doesn't have enough time to connect via BT so cannot check the BMS logs, but the rPi can sometimes manage to connect via BT4 and retrieve the values, when I force it on.
It has been sitting now for 1h, still nothing. Temps are at around 38C, well below the tripping point. Cell delta is 1mV.
EDIT: tried hooking up a jumpstart cable between the BMS terminals but the inverter still doesn't register the battery voltage, very strange. It also seems to be shorted inside since I am measuring 30 ohms or so between the terminals and a diode drop of 20mV both ways.
EDIT: the inverter battery fuse seems blown, I can measure the full battery voltage across it:
![1718813536445.png 1718813536445.png](https://diysolarforum.com/data/attachments/223/223145-556805085404888c708f2c42c8e58c1c.jpg)
Adding for reference some inverter and BMS graphs:
![1718813586714.png 1718813586714.png](https://diysolarforum.com/data/attachments/223/223146-10841e0956477574be6ff3fce0e1f43b.jpg)
![1718813613911.png 1718813613911.png](https://diysolarforum.com/data/attachments/223/223147-552d32ebcc179cd87389025a32f0e300.jpg)
![1718813642682.png 1718813642682.png](https://diysolarforum.com/data/attachments/223/223148-9057135893e5bf0bbe6df628ccd092bb.jpg)
![1718813706316.png 1718813706316.png](https://diysolarforum.com/data/attachments/223/223149-d68cea72e00c6b3b400de9b859e4b43f.jpg)
![1718813760966.png 1718813760966.png](https://diysolarforum.com/data/attachments/223/223150-354ac04f6e1fc5490b98ddab65d477fb.jpg)
![1718813961610.png 1718813961610.png](https://diysolarforum.com/data/attachments/223/223151-6931b0567837f804e0381d96e786636f.jpg)
Around 5:10pm there is nothing going out of the ordinary. The BMS temperature suddenly jumps from 37 to 38, but that's all. Looking at the detailed load, charge and discharge charts everything is very stable.
Odd to have two failures back-to-back.
