Yes, I'am talking about this.Not sure, but it looks like it is a calibration form where the user can input the resistance of the wires and connectors so this amount gets subtracted from the calculated value thus showing true cell resistance values?
Various things can occur but mostly imbalanced charging. Unlike Lead Acid based chemistries which are "Brute Force" all Lithium Chemistries are actually Millivot & Milliohn sensitive (hence the fancy BMS'). Equal Length battery cables & consistency is quite important especially when dealing with paralleled packs. You can run packs with different AH's ie 230, 280 & 304 together quite easily, larger differences (over 100AH) require some fancy math and working out averages for things like EndAmps/TailCurrent and understanding that they will charge & discharge proportionately in relation to their capacities.In the case of several batteries, cables of different lengths cause what problems?
