For what it is worth, I have a Pixel 5 running Android V13 and the app from the playstore installs and works on my phone.
I had one loose bus bar on one cell, that caused that cell to go overvoltage, and charge stopped, addressed that issue, all cells now well matched, but the SOC for that battery has an incorrect cycle count, and the SOC also will not correct itself after several cycles and doesn't appear to ever show 100%, then drops to 0% while I can still extract current.... so I would like to do a factory reset.
I see that the current App on android doesn't have the factory reset option, and that no one has reported which apk version has the factory reset.
I'll see if I can identify which apk version has the factory reset , but wonder what the process is to execute that. Do I need to disconnect the BMS from any charge source prior to executing the factory reset? Should I do the reset with battery near empty, or full, or does it not matter.
I realize the BMS needs to be powered on to do a factory reset, just wondering if there is anything I need to watch for, and what the steps are to re-set up the parameters or just push the Lifep04 button, then manually tweak the settings to the ones recommended by the experts here.
UPDATE: I installed the 4.12.1 APK on an older Android phone running Android 9. It installed fine, and connected to my problem battery 2. There is no factory reset in this version of the APK, and i also modified the battery capacity from 280aH to 281aH. I noticed that the cycle count reset to zero, and the battery SOC jumped from 0% to 68%, so my hope is this battery will now over the next few days go ahead and re-establish an SOC that makes sense. I am not sure what caused the cycle count to reset, and the SOC to jump, connecting with the new APK, or the battery capacity reset (my guess it was this change)... but I am happy for now, and have a zero cycle count (vs 359 caused by my loose bus bar), and am hopeful that this BMS will now recalibrate and report a reasonably accurate SOC.
I also removed that APK version and installed , and checked 3.7.5, 3.6.0 and 4.0.0 apks, and none of them have the factory reset option. If I get time I will install and try more of the available APK versions to identify exactly which APK contains the factory reset option. But the list of available APKs is long, and I have made progress on my issue so for now I will watch and wait.
Thanks in advance for any suggestions. (I have two 16 Cell EVE Batteries connected to a 15k Sol-ark)
