what can i doIf you are using a MPPT SCC in between that 12v power supply and your battery I am not surprised you get no output to the battery. SCC need a higher voltage to charge with. You can not charge at 14vDC with a 12.6vDC input.
Since I do not know what your battery specifications are, and why it is that you simply are not using a standard lithium battery charger, it is hard to formulate any response.what can i do
i have 100a li ion 4s battery 14V in cloudy days i get disel generator and from this generator i want to charge the battery and i watch same videos how to charge the battery using laptop chargerSince I do not know what your battery specifications are, and why it is that you simply are not using a standard lithium battery charger, it is hard to formulate any response.
If your laptop charger supplies 12V and the standard battery charger voltage for Li ion batteries is near 14V. Or you resign charging the battery with the laptop charger or you buy a DC-DC converter to increase the voltage from 12V to 14V. 12V is a too low voltage for your battery; that is not enough to have current flow from the source to the load (battery).i have 100a li ion 4s battery 14V in cloudy days i get disel generator and from this generator i want to charge the battery and i watch same videos how to charge the battery using laptop charger
its very hard for me to get charger in my country but are u short that the only probleme that i cant charger my battery is because the low voltage of the laptop charger im using because i can buy the dell laptop charger that has 19v
WHY DO I NEED DC TO DC CONVERTER IF I HAVE A MPPT REGULATORIf your laptop charger supplies 12V and the standard battery charger voltage for Li ion batteries is near 14V. Or you resign charging the battery with the laptop charger or you buy a DC-DC converter to increase the voltage from 12V to 14V. 12V is a too low voltage for your battery; that is not enough to have current flow from the source to the load (battery).
Actually the second proposal is what I did to build a cheap AC-DC station. I used an old Dell laptop charger that provides 19V and 100W power and attached it this DC-DC converter (with current regulator). I use this station to charge my LiFePo battery.
Now I can use AC to produce any kind of voltage from 0,6 to 36V but at max 80W; perhaps to slow for you to charge your battery.
VERY CAREFULL with the voltage you set the DC-DC converter. If you put the voltage at 15V and the full charge voltage of your battery is 14,2V you can damage the battery and the surroundings of it like burning a house and fireworks.
I have used old laptop chargers to charge various batteries but I use a DC to DC converter with a display and set it to the voltage of that particular battery. It is not a plug and play situation and one must be aware of both the Voltage and Amperage requirements of each battery which is being charged. This is very similar to the concept which @Jordi also posted earlier.i want to charge the battery and i watch same videos how to charge the battery using laptop charger
so if i use 19V 150watt DELL CHARGER i still be needing dc to dc or just regulator will work my battery i full charged at 16.8 v I CAN LIMIT THE CHARGER FROM MY REGULATORElectricity flows from higher voltage to lower voltage. You are trying to charge a 14V battery with only 12V thus there is no flow.
The MPPT can transform a higher voltage into a lower one and optimize PV production, but it can not increase voltage I think.
