Hi everyone,
I'm doing a large ground mount DIY system and was hoping you guys could help answer some of my questions. Please excuse me if I sound like a novice.
My 2 goals with this are:
I'm not committed to the IQ8 by any means, it was just the only microinverter I saw on SanTan.
My reasoning for choosing micro over string inverters was because I wasn't entirely sure how parallel arrays work with a central inverter, if multiple central inverters would be needed, and how those would tie in with the other components including our existing breaker box. If string makes more sense to you I'm all for it. I was just worried I'd end up with 20 inverter and combiner boxes or something strange like that.
In short, I am hoping to achieve a system of the fewest possible arrays, combiner boxes and tie-ins to the mains as possible. I'm having trouble finding information on what the limitations to these numbers are, so I haven't been able to put together a parts list yet.
If I forgot any information please excuse me again. Happy to fill in any blanks that might result in further advice. Thanks in advance forum people!
Ryan
- Here are the panels I found that I am considering: https://store.santansolar.com/produ...445w-144-half-cell-bifacial-mono-solar-panel/
- To be used with these: https://store.santansolar.com/product/enphase-iq8-microinverter/
- For the framing I am just going with 4x4's and 2x4's for a ground mount system. About 6' tall so I could access the inverters later if needed.
- My aim is to offset a small percentage of my usage with the option to expand in the future. I'd like to start with 100 of the 445w canadian panels above.
- My usage is 24.4kwh, 24/7/365.
- Would I need to notify the power company and/or get a grid tie if I'll never back feed to the grid, using a zero export device?
- Would I have to set these up in parallel due to the system size? If so, what is the maximum array size using the panels above?
- If I set up in parallel, would I need a combiner box for each array? If so, what is the maximum sized combiner box available on the market?
- Will I need any equipment besides these items: panels, microinverters, combiner box(es), cabling, mounting hardware, NEC labels?
- My array will be approximately 100 yards away from the mains, what size cable should I bury? Is this distance even feasible?
- Offset electrical bill by the maximum percentage possible with my current budget.
- Ensure system is expandable to ultimately reach 50% usage offset (during daylight hours of course).
Ryan
