HughF
Hi folks, long time off-grid LFP user, first time poster.
I'm building a Mason 280L with grade A EVE 304K cells, the whole lot sourced from Fogstar here in the UK.
Anyway, I've got a query - has anyone else taken delivery of a kit this last week and started to put it together? I ask because this seems to be the very latest revision of the 280L and has the mid-pack compression shelf, the V3 BMS, and the active balancer. All these are pre-installed, including the foam and cell tap PCBs on the mid-cell span brackets.
Where I'm going with this is; the supplied accessory box doesn't appear to be correct for this latest revision of 280L cabinet. There isn't a busbar to connect from the fuse to the P+ terminal, and the P- and B- busbars (three holes in each) are drilled with a different hole spacing to that on the BMS. The active balance harness' are also not included, despite the PCB being screwed in place and wired to the rear pushbutton switch.
I've sent an email to Fogstar with my queries but I thought I'd jump on here to see if anyone else is in the same predicament. It's not a major issue as I'm still running on my current pack (DIYd 6yrs back with CALB 210aH cells and Batrium) but I do need to get this assembled and swapped in by the end of Jan.
