I'm new to solar storage (been running grid-tied for years, but no battery storage). But I have been driving EV's for a few years now. For those, they recommend charging to 90% or lower to extend battery life, and never discharge below 10-20% (the car's "BMS" manages that). I was thinking I'd do the same with the solar battery bank, giving up some kWh's by not topping up to 100% every day, but limiting to 80 or 90%. But I'm reading so many articles about the cells needing to be balanced, and that seems to happen at the top end of the charging range (i.e. 100%).
My battery bank is going to be used for an additional set of panels (5kW or so) I'm putting in myself, running the Sol-Ark inverter in net-0 mode (no energy into the grid, but balance the house load w. panels and/or batteries). That way I avoid complex agreement changes with the utility, especially since I'm already close to the upper limit for grid-tied systems before transformer upgrades are needed (~20kW). The battery would also function as a "UPS" protecting electronic equipment from power outages (I currently have a "whole house" 3 KVA UPS that I'm looking to decommission).
So in my mind, depending on the season, I don't see the batteries (I'm buying 20kW) discharging below 40-50% and spending most of their life at a higher charge level. That's why I figured I'd let charging stop at 80-90% and let them sit there (extending longevity hopefully). But in reading this forum, it's unclear to me if that's unhealthy for the battery, and I should let it charge & sit at 100%.
Would like to hear from others on the forum how I should proceed with this setup and battery settings!
