As Solar Geezer and longtime member here I'll chime in a tad.
Battleborn 12V/100AH is $900 USD. Great Batteries & Good Company that "do it right".
Current the 280AH cells are the most popular as they are the Best Bang per Buck "today".
- Matched & Batched EVE-280's are 125.00 US ea. 4 ee required to make a 12V pack, $500.
- That provides 12V from 10.000V (0% SOC to 14.0V 100% SOC) All of the juice lives between 12.0 to 13.6V, LFP is very tight and has a flat voltage curve. This provides 3,584Wh or 3.58kWh.
- a 12V/280AH pack can output up to 280A for 1 hour (1.0 C-Rate) and can be charged with a Max of 140A for 2 hours (0.5 C-Rate)
4X 280AH Matched cells: $500
1X BMS capable of 250A Discharge and 125A charge, $200 and up pending on extras, features & functions of course.
OR lower Amp capable mosFET based BMS such as a 4S JBD 125-150 ish,.
1X MRBF 250A Fuse with bracket $25
- going higher end: 500+250+25 = $775 USD for 280AH.
+ Casing or frame as you desire, many options from DIY with plywood or ABS casings to whatever you can imagine as long as the interior is NON-Conductive !
There are MANY prebuilt batteries but NOT that many that are fully trustable. Will has reviewed many and boy... some were a real eye opener but others really stood out for being good quality. The big Commercial companies like Battleborn, SimpliPhi, Relion are Premium quality & priced accordingly.
If you download this pdf it will tell you most everything you need to know about assembling your own LFP Pack.
This document was posted to the forum by Amy from Shenzhen Luyuan and written by Steve S. It was meant to be posted as a resource. Below is her description of the resource: Dear all friends in the forum, This file in the attachment was...
diysolarforum.com
Hope it helps, Good Luck.
