@bedpan Thanks for your posting and updates.
Would you take a look at my posting here and let me know what you think? -> https://diysolarforum.com/threads/b...back-up-battery-replacement.65138/post-816535
I'm in similar situation where I'm about to drop $170 each on 4 x lead-acid batteries to keep my existing setup functional. I wanted to consider removing the existing _backup_ setup and just doing a simple 12V SUMP, 100-200A LiFePO4 with Victron charger and pump controller.
What's not clear to me is if I can :
- Simply connect the Victron Battery Charger to the LiFePO4 battery then from the 12V terminals that 12V backup SUMP controller and let the Victron keep the battery good-to-go. Of course I'd use Blue Sea terminal fuses and on/off switch disconnect. Can it be really this simple?
- I'm unclear if I really need anything else from Victron to make this for for a high quality LiFeP04 setup. Do I need any sort of other BMS or control setups?
