Hey folks. Not quite solar but mostly kinda related ;-)
I have a sump pump that runs quite a bit through Fall to Spring. 5 Years ago when I bought the house I put in a 12V battery backed up pump. This has worked quite good but I need a new battery for it. I have some Renogy 100Ah batteries (borrowed for now) so I put one in. It runs the pump fine but I get zero charging out of it. So I put a Renogy 20A charger on it. All said this works fine. The battery sits at 100% waiting on the pump to kick in should there be a power outage.
This led me to thinking.. I know its not great to leave LifePo4 at 100% all the time which is what will happen with the current setup. Is there a charger around that will maintain say 50%? I am ok giving up 50% of the capacity as its still functionally the same amount of pumping power as the old Lead Acid that was in there. If I can make the battery last long though I would like to do that.
So I guess 2 questions really;
1) How bad it is for LifePo4 to sit at 100%? Is there a measurable decline in capacity or not enough to worry about?
2) Is there a better charger, or some other means to keep the battery at 50%ish that is ideally automatic? I have pondered just unplug the charger when not in use and plug back in after a power outage.
Cheers and much thanks for the input!
