Bossrox
Solar tinkerer
I just got my 1st set of lith's & the top off is myffin' me. I have a weak charger to do the initial top off but here's what's perplexing me. With lead/acid you can see the voltage gradually rise & the amps decrease as it charges. I haven't got my 1st lith topped off yet & what I'm seeing so far is no voltage rise, it stays at 3.4v.
So what I'm wondering is, should I see a gradual volt rise like with lead/acid, or does it stay pretty flat until it reaches nearly charged then start to rise rapidly? Charging @ 3.65v & once a 3.2v lith is fully charged & disconnected from the charger, what volt reading should I expect & what is a normal resting voltage well after fully charged.
