The past few days I noticed my battery isn't charging much over 50%. And my invertor isn't trying. Usually it's running full tilt by 10 am and fully charged by about noon. I have 9 solar panels rated at about 3300 watts all together charging one lifepower4 100 AH rack battery. So it's been no problem getting a full charge quickly especially in the hot Arizona sun.
About 5 days ago, I noticed a short on my 12v power invertor output circuit, which wasn't fused. Wires had fused together and the 12v invertor went into protect mode. I separated the wires and the 12v invertor began working again. This is the only incident that has occurred that I am aware of.
Now, my display shows 334 volts, (not sure if this is normal for my system) about 50 watts and 0 amps charging power.
I checked my settings and reset the battery and EG4 invertor. Upon reset the invertor fans fire up and display shows some occasional higher sporadic higher voltage numbers 600, 350... then sits at about 250 for a few moments before nestling back down to a cool 50 watts.
I also turned off the battery and unplugged the solar panels for a hard reset to no avail.
Any insights would be greatly appreciated here.
UPDATE
Loads pull directly from the solar panels with no problem. I pulled 1500 watts and it came directly from the solar panels. Then disconnected the panels and pulled 1500 watts directly from the battery. No problem.
Then, the charging system fired up to replenish the power I pulled from the battery. The system thinks the battery is fully charged at 53%. The 50 watts were registering is the idle usage.
Why would my system stop charging the battery at 53%?
UPDATE
