jamiegreen
- Nov 8, 2021
- 182
Prior to upgrading to 48v, I ran a 24v system, with the solar capped to 60a. 8x 265w panels wired in 2s4p. Whenever the sun was out the controller always seemed to be capped at 60a (1.6kw) or there abouts.
Now on 48v with a much higher PV input, I seem to be getting less power. I mean, it's hot this past week, annoyingly hot but I'm sure the panels used to do better than around 1.1-1.2kw back on 24v. On the other hand on a cold day I've seen much higher outputs on 48v, but only.. once I think.
I'm wondering.. is my issue the PV input voltage maybe? If I recall it's about 60v in the sun, the MPPT seems to lock on around 58v most of the time. Victron recommends +5v over battery voltage though.. which it's just about. It's lifepo4 so around 54v.
Do I need to add another panel and make 3s? that would be kind of annoying given my panel layout but needs must if that may be the issue. Also the random dip in power is just me temporarily turning solar off.
Any ideas?
Thanks
Any ideas?
Thanks
