EDIT: I changed the title to better reflect the actual issue. 1/23/2024
This is the Power Queen trolling battery (12v 100ah), which I purchased 3 weeks ago on Amazon. I figured it was very similar if not identical to the Li Time trolling battery that Will reviewed.
I started cycling it about a week ago to see if it was functioning ok (3 full cycles so far). I'm using a little Imax B6 to charge it, which will only maintain 4.5a without over heating. I noticed that the rate of voltage increase on the battery would stall at around the 13.5V area. The voltage would also fluctuate +-0.1V which was not true in any other part of the charge cycle. It took 32.5ah to go from 13.47V to 13.54V for instance, and ~8ah more until the BMS tripped. It doesn't trip at 14.6V though; 14.1-14.2V based on the two times I've been watching when it happened. According to the Imax, the full charge takes 116-118ah.
Unfortunately I don't have a way to measure capacity by discharging atm. I've been using a cheap inverter looked up to a 250W heat lamp, with a Kill-A-Watt attached. The big unknown is the inverter efficiency, but the Kill-A-Watt measures 1,140-1,160Wh which is in the ballpark of what I'd expect. I have a battery coulometer on order so I can get an accurate discharge capacity and a 2nd opinion on the charging.
I've heard that there is very little loss in the charge-discharge cycle for LiFePO4 at reasonable rates... and I very much doubt this battery has appreciably more capacity than spec. The stalling at 13.5V makes me think it might have a bad cell and that the BMS is burning a lot of energy to try to balance them.
Does that makes sense? Has anyone seen similar behavior before?
Thanks!
Thanks!
