My system is a 2.5 kW with BB 24v 100ah batteries. The M+ is 24/2000 with cerbo (rsp) monitored through Victron VRM.
A BMV-712 is also part of the system.
Presently, the M+ is set to Solar and Wind priority and when the batteries or SOC get low I switch to "On" (grid) using VRM.
VE Config settings
The Charger tab on VE Config does not have Enable charger checked. I DO NOT want the grid charging the batteries, regardless.
What settings do I have to make so that when the battery voltage drops to a certain value the inverter instantly changes to grid?
I'm guessing the changes to made are in the Virtual Switch settings?
Here are my present M+ settings;
![01- General Tab.png 01- General Tab.png](https://diysolarforum.com/data/attachments/226/226013-e42437a4b993360cf414eb004a9e92f8.jpg)
![02- Grid Tab.png 02- Grid Tab.png](https://diysolarforum.com/data/attachments/226/226014-90f3805f9ebdf2186fbb64b46a28f64d.jpg)
![03- Inverter Tab.png 03- Inverter Tab.png](https://diysolarforum.com/data/attachments/226/226015-b3078ab12eb142ee72145a3a984520f4.jpg)
![04- Charger Tab.png 04- Charger Tab.png](https://diysolarforum.com/data/attachments/226/226016-cb6932843fd9082a1317ab4fff9d5624.jpg)
![05- Virtual Switch Usage Tab.png 05- Virtual Switch Usage Tab.png](https://diysolarforum.com/data/attachments/226/226017-8c617442b911cb2deed0b96c807304e9.jpg)
![06- Virtual Switch A Set VS ON Tab.png 06- Virtual Switch A Set VS ON Tab.png](https://diysolarforum.com/data/attachments/226/226018-5031c7e75df1bace01582610654e273b.jpg)
![07- Virtual Switch B Set VS OFF Tab.png 07- Virtual Switch B Set VS OFF Tab.png](https://diysolarforum.com/data/attachments/226/226019-b274eac5a19bef503711d50bbba6c9f6.jpg)
![08- Virtual Switch VS options Tab.png 08- Virtual Switch VS options Tab.png](https://diysolarforum.com/data/attachments/226/226020-ef964478135ade70ec7a80311095e589.jpg)
![09- Advanced Tab.png 09- Advanced Tab.png](https://diysolarforum.com/data/attachments/226/226022-ba1e9ce5531ca0f4779378b8bdbf14b5.jpg)
VE Config settings
