OffGridForGood
Catch, make or grow everything you can.
I bought a 50 Acre property, about 20 miles from my home. It has grid connection with 200A panel in a 2000 sqft insulated but unheated cold storage building.
240 foot deep well, 1Hp 240v well pump,
old style flourescent lights (yeah LED's are on the list).
The property has Grid connection that basically costs $40.00 CAD per month for using zero power, ie $30USD per month/ $360.00 USD per year.
It would be easy enough to build a small isolated off grid system but to be cost effective, I would want that system to be able to run the well pump, and some hand tools (skill saw/battery chargers, lights etc. without the grid. The total cost would need to be no more than 6-7 years of just paying the utility rate - lets say 2500 USD max budget. The building is unheated, so I need either heated box with LiFePO4 in it, or AGM. And since the batteries are the expensive part of any build, the AGM make better sense likely.
For the discussion, lets say my max power use is a day at this location:
Lights 1.2kW x 6 hrs, 7kWh
Well pump peak may need 6kW for starting, but will only use 1kWh of energy,
chargers and misc items lets say 2kWh
10kWh of storage, peak starting 5-6kW.
lets' ignore the PV for now, since a very small PV input would easily charge the system during long periods between site trips.
What could I build for $2500 or do I just leave it on the grid?
