12VoltInstalls
life passes by too quickly to not live in freedom
I don’t find the British conservative at all. Traditionalist and inflexible maybe. But not conservative.there's not many people nearly as conservative as the British.
After all, 15% is no where near a passing grade.Now the trend is to nominate the steepness as a percentage of the angle from horizontal to vertical i.e. 15%. Why anyone would want to make it more complex
In my mind temperature is the only quantification where ‘metric’ makes any sense. In fact, ‘metric’ is an abortion of language: any comparative system to denote a distance or neo-linear measurement is ‘metric’ while the word itself denotes a standard more related to timing than distance.more intuitive as freezing is 0
Part of an anchoring system?!!rode
And there’s the 12 again. 12 yards plus the leftover meter parts times 12 is twelvish meters LOL?Yards are very close to metres, actually, so that wouldn't make much of a difference
Well, if you happen to be boiling water at sea level, sure.it does make sense that 0 is freezing and 100 boiling, doesn't it.
You have to boil water at sea level to have fresh mussels ?Well, if you happen to be boiling water at sea level, sure.
Meters are longer than yards by about 9.3%. Twelve yards is really close to eleven meters.And there’s the 12 again. 12 yards plus the leftover meter parts times 12 is twelvish meters LOL?
Good point. Of course, if you exercise in the mountains, you can have fresh muscles there, too.You have to boil water at sea level to have fresh mussels ?![]()
39-3/8” in a meter. If they were going to make stuff up at least they could have made it measure to an even inch. 0.03125” is cumbersome to calculate with.Meters are longer than yards by about 9.3%. Twelve yards is really close to eleven meters.
Define conservative.I don’t find the British conservative at all. Traditionalist and inflexible maybe. But not conservative.
Much of the lumber I use comes off my own land. When I bring it home from the sawmill it is full dimension. A 1"x12" black walnut board is exactly that and is rough sawn. Same with a board of eastern red cedar. That's how all lumber sold is priced, just as it came from the sawmill. Then it is planed smooth on all sides and around 1/4" of material is removed from all surfaces resutling in a 2"x4" measuring around 1.5"x3.5"OK, here's a question for those if you in metric land. Do you have sane material measurements or are they as confusing in other countries like they are in the USA? For example, go to the store and buy some lumber for building a house. In the USA the most common piece of lumber used for wall studs in known as a 2x4 where that means 2 inches x 4 inches. These typically come in 8 foot lengths (but also 6, 10, and 12 feet). But here's the thing - a 2x4 is not 2 inches by 4 inches. They are actually 1.5 inches by 3.5 inches. That's just one example. When I built my trailer I made most of my cabinets using 1x2 boards. Nope, not 1 inch x 2 inch. They are really 0.75 inch by 1.5 inch.
And let's not go down the rabbit hole of how pipes are measured.
How is lumber typically designated and actually measured in other countries?
a good laugh, a stronger sense of unity and a great forum to also relieve some stress of the day. All in good spirit.@brandnewb I'm really confused about what you are trying to achieve with your posts.
The older generation that helped me build my home did speak in 2 by 4's or things to a similar tone.OK, here's a question for those if you in metric land. Do you have sane material measurements or are they as confusing in other countries like they are in the USA? For example, go to the store and buy some lumber for building a house. In the USA the most common piece of lumber used for wall studs in known as a 2x4 where that means 2 inches x 4 inches. These typically come in 8 foot lengths (but also 6, 10, and 12 feet). But here's the thing - a 2x4 is not 2 inches by 4 inches. They are actually 1.5 inches by 3.5 inches. That's just one example. When I built my trailer I made most of my cabinets using 1x2 boards. Nope, not 1 inch x 2 inch. They are really 0.75 inch by 1.5 inch.
did I do it incorrectly again?It's sometimes soo diffucult
“It’s” is the contraction of “it” and “is”. “Its” is the possessive.did I do it incorrectly again?
it's is possessive and in the meant context make no sense?
