zanydroid
Solar Wizard
This presumes that the LVPs are actually implemented correctly / correct configuration is set. With that tier of equipment I wouldn’t be surprised if it is equally or less flaky than the POCO meter and IT.Op should stand on the fact his system cannot feed the grid and is not in parallel and then make them prove they are seeing back feed
If air gapping eliminates the backfeed detection then it was likely parallel despite whatever is in manual or believed to have been the config.
