Will,
Love watching your Vids.
I will be mounting a 100 Watt Renogy Panel to the top of my 28A Majestic (CA) in order to keep my Engine AND House battery charged while in storage.
Using your video as a guide, I am thinking to run the wires down the front, using Wire Channels/Guides to the bottom, where I can from there put my (Dual Battery controller - EPEVER EPIPDB-COM Series Dual Battery Solar Charge Controller 20A),
Are there any idea's/drawbacks to using this method?
Also - Because of storage both battery tends to discharge to the point where I must jump the battery to start the engine, and jump the house battery to get the generator going as well, unless I drive around for a while and charge both up. The question I have, is have the two wet cells discharge doing damage? Will I have end up having to buy new ones? I assume maintaining the batteries using the Solar charger will be a big plus??
Thanks
Larry W
Thanks
Larry W
