Greetings.
I am in the process of purchasing three more 200 watt panels from Renogy_Solar on Ebay for a total of 10. My plan is to mount two rows of five panels each on my metal roof. The roof will be grounded to an 8 foot grounding rod sunk into the ground. I assume that would be sufficient? They will be connected to an Ecoflow Delta and two River Pros, each with the additional battery. That comes out to about 4,140 watt hours by my calculations ?? I intend to use this system as backup in the event of a prolonged power outage in these troubled times, but the plan is to use it on a continued basis to help a little on the utility bill.
I have several questions about this process. Apparently the people at Renogy are having problems with the language barrier.
With all the heat retained on a metal roof, will this have any kind of negative effect on the output of the panels? If so, please share some input on how deal with it.
The ridges on the roof appear to be about 1/4 to 1/2 inch too high for the panels to be mounted over them when using Renogy's mounting bracket kits. Would it be wise to use a section of 2X4 as a buffer and beat the ridges down just in the places required to clear the panels, or should I use some kind of shims?
Does it make sense when cleaning the panels to use just a clean cloth, with a little water if needed, and no soap of any kind?
Thanks in advance for your help.
Renogy Solar Panel Mounting Z Brackets Set For Solar Panel Flat Roof Wall | eBay
Find many great new & used options and get the best deals for Renogy Solar Panel Mounting Z Brackets Set For Solar Panel Flat Roof Wall at the best online prices at eBay! Free shipping for many products!
www.ebay.com
