Zwy
Emperor Of Solar
[Moderator Note: This discussion has been moved to its own dedicated topic, from a post where it was distracting from/tangential to OP's post, and derailing the conversation. And also an example of less-than-excellent communication on both our parts. Rather than deleting any content, its been moved to its own topic, in the interest of transparency and in case anyone finds two strangers on the internet mostly talking past each other and disagreeing in a less-than-constructive fashion to be of any value.]
If we look at Multiplus in 24V, 3000w it shows idle again at 20w. That means we can see a 16w difference between the GW and Victron. That's 384w for an entire 24 hour period if one left it on all day and night, which I have a remote switch to turn it on and off easily and doesn't account for PV input once batteries are fully charged.
Let's quit with the myths about AIO idle consumption. It doesn't matter unless there is one 100w panel supplying a 50Ah battery. And even then with a switch to turn off the inverter while it is not in use would probably work.
I've seen you mention this several times about idle consumption and I'll give you what I have found. Under 1.5 amps (it does go between 1.3 to 1.5 amps) on 24V is what my Growatt SPF 3000 LVM has for idle consumption and that is actual in the field usage. Now, let's look at Victron based upon their published specs. The Phoenix 3000w inverter draws 20w No Load Power, it can be set to draw 15w and 10w with AES and Search mode, but let's be fair, as I never set my GW in any Search mode, I never found it necessary.I personally don't know much about all-in-ones, the simplicity is appealing, but the trade-offs have never fit my personal preference. The Victron Easysolar is the only one that has piqued my interest but its not available in the states.
The main thing I would double check when looking at AIO's is the idle power consumption (and also make sure you understand the different ratings--many newbies often misunderstand what rating applies to what function of the AIO).
