Did you change the setting to Solar first for charging or something like that?.Battery is 42.3v... Have everything hooked up correctly. I'm not getting any charge from the pv. Says 0. I don't have a 48v multi meter either. If I had something hooked up wrong there would be sparks &/or fire. No sparks or fire so I'm pretty sure I hooked it up correct.
I saw that setting but no, I did not change it. Seamed like a option. I'll change it now. Almost dark but maybe enough light to get a reading.Did you change the setting to Solar first for charging or something like that?.
I think its the first setting.
Literally with a magnifying lens. Print is so small I was looking for pages in settings... Eyes going fast ;( Most those settings were way over my level of understanding. I just assume thats mostly fine tuning stuff.Did you read the manual and go through the settings?
Could your battery be so low that it is below the lockout voltage?Battery is 42.3v
If there is a low battery lockout setting. What is the voltage range of your battery?How can a low battery stop the solar power from coming in?
In the settings I set it at 44vWhat is the voltage range of your battery?
That is above the 42 volts you said your battery measuredIn the settings I set it at 44v
It turns on & I can go through settings.MPP will need power from the battery to run. If it is too low, it will not start.
I just used the values I found on Relion's siteThat is above the 42 volts you said your battery measured
You have to lower the setting temporarily or charge the battery some other way. Also you should lower the charging Amps until the battery gets to 44 volts.The Catch 22 is they don't expect anyone to run their battery below 44 because it is not good for the battery. How did that happen? Did it arrive that way?Sounds pretty catch 22 if the battery has to be x volts to charge. How do you charge a 48v battery that the charger wont charge it unless its charged...
My guess is I got a bad battery. Just turned it on 2 days after it showed up at 42vHow did that happen?
