Stefanseiner
Hello,
after one year of usage my MPI 10k seems to be defective.
You can see the whole project here -> 100KWh DIY 18650 Powerwall in Germany
Without grid connection it runs fine, but when I connect to the grid then the external fuse (Siemens 3x B16A) goes off.
at minute 0.50
- I double and triple checked all the wire connections including grounding and external circuit breaker
- I changed the fuse to a slower "C" rated model
- grid voltage is stable round about 230 volts
I changed the three phase wires in all possible combinations to avoid wrong connection
B / G / S fuse off S lights up in Siemens fuse
G / B / S Error 09 line phase loss
G / S / B fuse off B lights up in Siemens fuse
B / S / G Error 09 line phase loss
S / B / G fuse off G lights up in Siemens fuse
S / G / B Error 09 line phase loss
B = brown phase wire = phase 1
G = grey phase wire = phase 2
S = black phase wire = phase 3
Do you have some idea what's wrong or what could be defective?
Thanks and regards
Stefan
at minute 0.50
Thanks and regards
Stefan
