4KW per input. (period)
2 times 8 is 16, not 19.
VOLTS times AMPS equals WATTS.
When it gets cold, the Voltage goes up, not the amps. Cold is below 30°F. It's not digital, the colder it gets the more resistance the wires have until they warm. There is a very high probability the voltage will be at or near VOC when below freezing temps. During warm and hot temps the voltage will not be near VOC.
If you want more than 16 kW PV, get more inverters in parallel or bigger rated inverters
In an off-grid build, you have to build the array to what the maximum possible sunny day might be during summer. Not what the least amount of sun will be during winter.
