Believe or not this problem exists in the WP version as well. Not sure what is causing it. Didn't even think about possible noise interference. But now that you mention it, I might have to find something to separate mine since my current sharing cables and the output wires are in the same wireway for mineGreetings everyone, I built a system with 40kWh of batteries and three LVX6048 inverters powering an off-grid ranch and I have a curious issue. Beyond this issue the system is fantastic.
Every few nights, the power blips off and on for a few seconds. It is not every night but it only occurs at night. This is not related to overload as the loads are far under 50% of inverter capacity. Finally, this appears to have no correlation to battery SOC. I've also had them shut off two of the inverters and it still occurs.
Settings
SUB
APL
Photo Note
Suspected the resets might have been due to noise from ac output getting into the balance/current sharing cables so those are now unbundled from the ac lines and ran separately.
Thank you!
Odd considering as I understand that those are different manufactures. Does anyone have ideas on what is causing these seemingly random resets? The ranch owners are extremely happy will all their newfound power but the random resets are confidence shaking. No errors on the units.Believe or not this problem exists in the WP version as well. Not sure what is causing it. Didn't even think about possible noise interference. But now that you mention it, I might have to find something to separate mine since my current sharing cables and the output wires are in the same wireway for mine
It's the same manufacturer, for sure. I just thought a lot of the problems from the non-WP version would be cleaned in the WP version, but alas, here we are.Odd considering as I understand that those are different manufactures. Does anyone have ideas on what is causing these seemingly random resets? The ranch owners are extremely happy will all their newfound power but the random resets are confidence shaking. No errors on the units.
Both Voltronic PowerOdd considering as I understand that those are different manufactures. Does anyone have ideas on what is causing these seemingly random resets? The ranch owners are extremely happy will all their newfound power but the random resets are confidence shaking. No errors on the units.
I have 3 LVX6048's. I have been fighting this issue for months. I have tried separating the comm cables, shielding them, and a few other things to no avail. It is frustrating because it resets a bunch of things in the house, in fact I had to buy a small UPS for my router and modem so they wouldn't go down. At first it only happened during the night, but now it happens at any time and it changes random settings on the inverters. Weird because it doesnt reset them to default and its not the same settings all the time. I use "user" settings for the batteries and it always resets them to agm and changes my values. I dislike my inverters. I get a lot of fault 60 (and other random faults) and have not been able to use one inverter except as a battery charger for 2 months. Ian has now sent me a relay board to change, but I just received it and we will see if that works. I have to switch the house back to grid every time I leave for a while because these are so unreliable. They don't seem to play well with the grid either. If I turn off grid input to them they are much more reliable and way less noisy - not sure how those things correlate. I often think that maybe its just a setting that needs to be changed but I change things periodically and nothing ever gets better. I should start a thread for people running these in parallel as when in single mode there doesn't seem to be this problem. In this thread we could all share settings and what issues we are seeing. If anyone is running these in parallel and they are running perfect, please DM me or reply here so I can pick your brain a bit.Greetings everyone, I built a system with 40kWh of batteries and three LVX6048 inverters powering an off-grid ranch and I have a curious issue. Beyond this issue the system is fantastic.
Settings
SUB
APL
Photo Note
Thank you!
3/4" conduit fittings fit fine (at least the sch 80 PVC ones do).aren't meant to connect conduit to
I sure I hope I have better luck with mine, but I am running my two separately feed different sub panels.
Not sure how you stumbled into this thread, but about 10kwh if you go from 100% to 0%, figure 8kwh usable for LiFePo4, 5-6kwh for lead acid.Hi, if I have 4 , 12 volt battery 200A wat will be Watts that Will produce the battery. My system is running 48volt. Thanks.
People keep telling me to get the top tier stuff...and don't look back. Go for Sol-ark or something. It's steep yes but tax credits do help. I still like to mess with the chinese inverter though because there is hardly any payback with battery banks and every bit helps. I can buy a lot of chinse inverters for the price of a Sol-Ark. If you don't like to tinker stay away from Chinese inverters. I am still working with MPP on mine where the inverter goes bonkers if I bring in more than 1.5k of solar but only if i turn on the heat pump.Hello, I'm new to the forum here, and I think that I've read this entire thread. Lots of good stuff in here.
I'm looking for some help.
I bought an LVX6048 just over a year ago from Ian there at watts247, and had finally got all the bugs worked out of it, or so I thought. 18 370watt panels 6S3P making about 12 to 15 kwh a day. Decided to add some batteries to the system and try to improve my power generation. I started with some old CAT batteries paralleled for 48 volts. My system was working pretty good until one Sunday morning I found it DRT, dead right there. NOTHING, just a faint hum.
I happen to live in Utah about 4 hours away from watts247 and needed to make a trip down to Nevada, Ian said that I could drop it off on my way by and he would get it repaired. He had to replace the main board to get it going again. Ian at watts247 is great with customer support!
Back at home I got it all hooked back up and figured it was running well. Two days later I noticed that my batteries were going flat. I messed around with the settings trying to get her to charge up the batteries with no luck. I got in touch with Ian again and we tried some stuff: flashed the newest version of firmware onto the unit, installed a new control board, got newer better batteries and an equalizer for them and installed a new relay board. No change... it still wont charge the batteries. Only the MTTP board left to change out... but I'm not sure that will do it.
I'm still working with Ian on it. Hopefully today I can figure out how to get it hooked up to the the laptop and do a factory reset on it. If that doesn't work I'm not sure what else to try.
Have you ever seen anything act like this?
Please let me know if you guys have any ideas.
I'm with you.People keep telling me to get the top tier stuff...and don't look back. Go for Sol-ark or something. It's steep yes but tax credits do help. I still like to mess with the chinese inverter though because there is hardly any payback with battery banks and every bit helps. I can buy a lot of chinse inverters for the price of a Sol-Ark. If you don't like to tinker stay away from Chinese inverters. I am still working with MPP on mine where the inverter goes bonkers if I bring in more than 1.5k of solar but only if i turn on the heat pump.
Oh that's easy, took me a few mins the other day when mpp wanted to pull some logs. Just use the micro-usb port, install software, hook it up, done. The trick is to have 3 cables on hand because only 1 will work for data. The 3rd one I tried did the trick.I'm with you.
Most of the time I can't help myself. I love to tinker on things. The Chinese stuff always provides plenty of tinker time and learning opportunity.
Has anybody figured out how to tie into the lvx6048 with solarpower on the laptop?
You mean 3 USB micro to USB cables?Oh that's easy, took me a few mins the other day when mpp wanted to pull some logs. Just use the micro-usb port, install software, hook it up, done. The trick is to have 3 cables on hand because only 1 will work for data. The 3rd one I tried did the trick.
right just the regular micro usb, no need for rs232 or an adapter, that's why they made the micro usb portYou mean 3 USB micro to USB cables?
Not the rs232 to USB adapter?
