travisandblair
- Jun 3, 2022
- 11
I am having an issue and I can't seem to troubleshoot the problem. My system is exclusively for a detached shop I am trying to run off grid. LVX 6048, 48v Trophy Battery, SanTan Solar used panels 240W 37.2 VOC 2 parallel strings of 10 in series run through a branch connector. At night I don't have anything powered up that can consume electricity except for 1 power strip that has an LED light and a USB converter built into it. Everything else is either unplugged or turned off. I understand the higher consumption rate of the LVX 6048.
(Disclaimer - all of this troubleshooting was done in full sun with no partial shade)
I had the solar panels temporarily on the ground for troubleshooting until I fine tune the system. Everything seemed to be working fine until I went out and my battery was at 32% SOC one morning and not charging even though the panels should have been producing enough power to charge a little bit. (The input on the LVX showed 295V and 516W input from the array). I started troubleshooting panels and found that each array was indicating on a voltmeter 330Vdc. I went to check the resistance and sometimes it was 0 ohms and sometimes it would not register (indicating there is no continuity through the panels). I started checking each individual panel, including pulling the covers off of the back of the panels to check the diodes. Sometimes the panels would have 0 ohms, sometimes not registered. All of the panels showed approx 33 Vdc through the panel though.
I tried to isolate individual strings, and eventually ditched the branch connector to wire just 1 series of 10 panels directly to the LVX and immediately got 330 Vdc and 2kw input showing on the LVX. The battery started charging up with over 30 amps, and things were looking good.....Until a few hours later when I went back out and the battery stopped charging at 78% SOC and the LVX showed back to the 250V and 500w (fluctuating). But the sun condition was exactly the same - full sun, no shade, no load change, etc. I am very frustrated.
I already had problems with 1 LVX 6048 and had it replaced by Ian at MPP Solar US (he did an awesome job with customer service btw) and I hate to bug him again. Especially if I can't tell if its my panels, the battery, or what.
I am about to throw the whole thing in my pond and wire up my shop from the house.
Please help if you can.
