mesquito_creek
- Feb 8, 2021
- 146
I have a new mpp solar LV6048 with bigbattery 48V 125ahs. It won't use the 120v utility input? BigBattery shipped the batteries discharged at 42.8v but I have successfully charged 1 of them with my PV 1600watts to the point where the inverter will turn on. Now my assumption is that at some point the inverter/charger will use the grid to charge the battery? My battery is still pretty low so when I connect a load I get a low voltage warning. But I assumed that the grid line in should pick up the load and the grid line in should help charge the battery! I have even set it to 01 - Utility First and 16 - CUT (Utility first). My output is wired to a breaker panel and set split phase 180 degrees. What am I doing wrong? Should I wait until the battery is fully charged, even though that defeats the purpose of utility first? When I hook up WatchPower I see LINE_FAULT in the event log.
