Hello Forum Colleagues,
I already posted this as a reply in a similar topic (Growatt inverter related, same problem), but I thought to also open a separate topic and try to get and advice on how potentially this problem can be resolved, from someone that experienced the same and maybe found a solution for it.
So long story short, this has happened/is happening to me with two different inverter models, from two different producers --> hybrid MPP Solar PIP6048MT 6kW, the one that I recently bought and I have now installed in my PV system, and the previous hybrid inverter from Powland 5kW (exact model does not matter now), that I have replaced. In the morning, the inverter does not see the real & correct PV panels voltage & wattage and keeps on pulling energy from battery to power the loads, even if I have the battery 100% charged (PYLONTECH US3000C - 1 unit), and I know for sure that the panels produce enough to cover my current home loads/appliances. Which by the way, are below 250Watts during the night and until the early morning. I have to cycle the inverter at least once or twice before the MPPT module kicks in as it should, and the voltage/wattage production is displayed properly. I even tried to "combine" the different settings available from prog. 2 and prog. 16, which are the source for powering the loads, and the charger source priority respectively. Nothing appears to be working from what I have tried, and I have to do the same thing each and every morning, when I want to switch from the utility/the grid, to the PVs. Is this related to an incorrect setting or a combination of settings that I might missed ? The inverter has a 500 volts VoC, and the MPPT voltage range is between 60v and 450v. My current PV configuration is formed of 12 panels in series (375W from Canadian Solar), so around 4,500Watts theoretical capacity. I would like to mention that my intention at some point is to add more PYL batteries and go totally off-grid/no utility power, and I am currently still testing the system. But I do not want to have to cycle the inverter each and every morning, to kick-start the MPPT module.
Anyone else that experienced the same problem and can bring some light ? Any additional information that I might have missed or useful advice, would be more than welcome and much appreciated. Thank you in advance !!!
Regards,
Sorin
Regards,
Sorin
