timselectric
- Feb 5, 2022
- 25,303
It's ok.The sad part is I've realized my solar batteries will probably out live me.
A lot of us are in that age group. lol
Don't feel bad, I plant trees that I likely will not see to maturity, but I do it anyway!The sad part is I've realized my solar batteries will probably out live me.
I just celebrated the same birthday, for a second time.I just stopped having birthday's - so I don't get a year older each year.
There are always more levels of protection, that can be applied. But you have to weigh the likelihood against the cost and effort.
Enough Voltage can create a arc across a gap. And enough amperage can sustain the arc.
Too much amperage on a conductor will create excessive heat.
Both of these conditions can cause a fire.
My point is that a battery built in a wooden box or frame, isn't a problem. As long as it's done properly.
Can you build your system in an underground concrete bunker, and feel safe? Yes
Can I build my system in my bedroom and feel safe? Absolutely.
You don't have to be afraid of electricity, but you do have to respect it.
You know that you are getting old, when you forget how old you are.
But on a good note, I was wrong last year. So, I'm younger than I thought. lol
That was the downside of my birthday mistake.I lost track of the number of times that I have celebrated my 29th birthday a long time ago, but now I'm like a kid again, just counting in reverse to retirement.![]()
What’s that? Hope I never grow upone more extra year from retirement
and it is safe because the wire sizes are large enough and the breaker sized to protect those wires from overheating if they do see excess currents (which they shouldn't see if sized properly for their use). so we should learn and do the same for our solar set ups. Size wires properly for the loads, use fuses and breakers to protect those wires from excess heat under load.Common house wiring is attached to or fished through wooden structures. No fire risk.
A failed connection falls under improper installation.
There are a lot of what if's that can happen. You just have to pick which ones you are more concerned about.
What if there were an earthquake.
If the battery fell over. I would much rather have the terminals contact wood, than metal.
I purposely avoided any conductive materials around my batteries. My biggest concern would be a short across one cell. But I'm not going to place a fuse on each individual cell.
My DIY battery boxes (3/4 inch birch ply) are lined with 1/4 inch rubber floor material (also serves as a bit of cell compression relief). The floor of my shed also has the same rubber sheet flooring.I also prefer installing in a non conductive setting. I do have doors that can be closed and locked if needed to protect from young curious minds if needed.
I spent five years in southern Indiana along the Ohio River. Humidity there was very high. Don’t recall any forest fire alerts during those days.takes a bit of effort to burn wood, around here
I'm across the river from there.I spent five years in southern Indiana along the Ohio River. Humidity there was very high. Don’t recall any forest fire alerts during those days.
I can see the rubber for electrical isolation - but if it were to catch fire, rubber burns/makes smoke - I think this is why they use the fiberglass sheets between the cells typically: electrical isolation without being a smoke/combustion supporting material.My DIY battery boxes (3/4 inch birch ply) are lined with 1/4 inch rubber floor material
Dry wood is a fantastic electrical isolation material, wet wood not so much.Humidity there was very high
That’s why it’s in a shed. It’s not a EV. Besides, the spray foam in the walls, floors and ceiling would likely release worse stuff. At some point, more and more risk mitigation starts running into the of law diminishing returns.I can see the rubber for electrical isolation - but if it were to catch fire, rubber burns/makes smoke - I think this is why they use the fiberglass sheets between the cells typically: electrical isolation without being a smoke/combustion supporting material.
Fire Marshal told me once: "Smoke kills far more people than fire"
on the flip side, dry wood can burn easily, but wet wood not so much.
I built my DIY cells into packs in birch ply boxes too, and like @timselectric I was mostly concerned about the isolation of the cell cases so used fiberglass sheets in some, and the stuff they call 'fish paper' (you see this in electronics; kinda green stiff paper stuff) in the others, since it was thinner and cheaper than the fiberglass sheets. I like the physical protection of the birch boxes, using a non-conducting material instead of metal, lets' me sleep better.
Ah yes. The true reason we are here and bounce our ideas off of others.lets' me sleep better.
I agree,That’s why it’s in a shed. It’s not a EV. Besides, the spray foam in the walls, floors and ceiling would likely release worse stuff. At some point, more and more risk mitigation starts running into the of law diminishing returns.
I would not do what you plan on a house system. On my truck camper, I mounted a toolbox to the rear and installed the Growatt AIO inside. It does get quite warm in there even with the inverter off and just the MPPT charging the battery. Yes, it does have a fan and outlet that is thermostatically controlled.I'm inclined to put all of the solar controls into a steel cabinet and run the #2 wires to my multiplus 24 2000 which will be mounted next to the steel cabinet (with a door on it)
Put some fans in there to cool the equipment.
Why? I want to contain a fire in the event something bad happens.
Any opinions?
