Lt.Dan
Solar Wizard
I thought some people might be interested in this. I saw an ad for it. This is the first ceiling cassette I have seen that fits between 16" Studs!
This works great for people who only need 1 unit, but don't have the wall space for the indoor unit.The issue with mini-splits, multi-zone is each ceiling cassette ( or wall air handler ) has a dedicated line set, thats alot of copper to be running around and places for leaks of the refrigerant.
My choice was a ducted mini-split, so you get all the advantages of variable load technology with a standard central air-handler.
I wanted to thank you VERY MUCH for posting this. My wife and I decided to go with their furnace replacement unit and do central air since we have central air gas heat now.This works great for people who only need 1 unit, but don't have the wall space for the indoor unit.
I'm seriously considering one of these for my garage.
Right on! I'm trying to find where they are for sale though? I can only find their standard square/larger ceiling cassettes?I wanted to thank you VERY MUCH for posting this. My wife and I decided to go with their furnace replacement unit and do central air since we have central air gas heat now.
It was going to cost $15,000 to get an ac place to do the system and with what I found on that site plus experience doing mini splits for years we decided to go with them for the entire house heating and cooling. The house is 4000 square feet so I'm going with 2 of the 3 ton units.
Again the wife and I wanted to thank you since you just saved us $8000 easy.
It could just be a pre release announcement.Right on! I'm trying to find where they are for sale though? I can only find their standard square/larger ceiling cassettes?
Where did you get it?I’m installing one of these right now. I’ve got the cassette electrical done and hole drilled for Lindsey but I need a very long ladder (20ft) in order to first mount the line set covers before I can go run the line set. Ask me if you need any impressions on the unit.
https://avidehome.com/ was the cheapest, no tax. I needed a custom package which was 3 zone condenser, regular 9k wall air handler and the 18k ceiling cassette.Where did you get it?
Ducted are not as efficient due to losses from the ducts. That is well known. An air handler type has it's place in a home, don't get me wrong.The issue with mini-splits, multi-zone is each ceiling cassette ( or wall air handler ) has a dedicated line set, thats alot of copper to be running around and places for leaks of the refrigerant.
I remember when you mentioned it to me. https://diysolarforum.com/threads/best-way-to-use-excess-solar-to-offset-gas-heat.60418/post-748718I’m installing one of these right now. I’ve got the cassette electrical done and hole drilled for Lindsey but I need a very long ladder (20ft) in order to first mount the line set covers before I can go run the line set. Ask me if you need any impressions on the unit.
I'm installing a Pioneer floor model in my living room now. Too many windows and I think the floor model will work better for the install and cleaning.Ceiling cassettes are great for rooms that don't have a good wall location. But do have attic space above.
And they're much less conspicuous.
I'm no A/C guy, but I'm pretty sure you also loose air speed with ducting, reducing your cooling capabilities as well.
No reduction with linesets up to 75' or 100' I think.
Have a link to the ducted unit you bought?The issue with mini-splits, multi-zone is each ceiling cassette ( or wall air handler ) has a dedicated line set, thats alot of copper to be running around and places for leaks of the refrigerant.
Thanks for the info on the heat mode energy use.Ingram water and air is the primary retailer in the US for Mr. Cool.
I've bought three of the standard DIY split units from them, a 9, a 12, and a 24K btu. They've been fantastic.
I will say though, if you use them for heat they can get spendy. We still have the old LNG central furnace - the AC went out years ago. It's not that cold here, but wife works from home so I would set the gas furnace, then turn on the 2-ton unit for heat in the main part of the house with 15' ceilings - we got a $460 electric bill that month so I quit turning it on. Cost dropped back to $260 for the month.
So we use ours for cooling here in So-Cal. Electricity averages 47cents a kWh here. Ouch!
