NorthTown2022
I already have two loads connected to the converter through a dinn rail terminal block. I want to add a third. The total wattage the converter can handle is ~288w, and with the third load will still be only ~100w to 150w.
Is there a preferred method for combining all these small loads AND what is the best over current protection? Finding low wattage 48v fuses and holders are an issue on their own. I can only assume I SHOULD have fuses or breakers installed?
